Teco jn5-cm-tcpip
ianingram
Apr 2002
Newcastle
457
Hi All,
I am looking for any information on a communication option for a TECO VSD, Part Number JN5-CM-TCPIP.
The VSD manual makes reference to another manual for this option card, but I just cannot find it on the 'net.
I need to be able to connect the VSD(s) to an IDEC PLC via an ethernet switch.
You realize (I hope) that this is NOT the actual VFD, this is a TCP/IP Ethernet adapter for a Teco F510 VFD...
Umm, Yes, the VSD(s) (2 of) are in another panel.. And they are a Teco A510 VSD's.
Just been emailing Teco support in Oz, there is not much info on the 'net, hoping that someone else here have used these before
I was directed to download some Lantronix software ("DeviceInstaller") to configure these units with an IP address (similar to A-B's BOOTP utility), but the Lantronix software is not finding the devices...
Sorry, I just re-read your question and you were more clear than I originally thought...
I get accused of being too pro-A-B, but honestly, this is why. I used to work on Teco drives a lot and although they aren't bad as inexpensive shaft turners, when it comes to integrating them into something smarter they leave a lot to be desired. I had a similar experience trying to integrate them into a DeviceNet system with their similar module. I eventually gave up and bought A-B drives instead. My time was worth more than the difference in cost of the drives.
Yes, I normally exclusively deal with A-B products, and their support systems are so much better..
I have been sent a small manual (attached), but unless I can get this Lantronix software to see the devices, there is not much that I can do, other than buy some analog output cards for the IDEC PLC (not even sure if I need speed control on this project yet - I do have some spare digital inputs/outputs for run feedback/command signals).
Anyone have some info for how to control a TECO EQ7 series VFD via Modbus RTU? We originally installed a pair of Yaskawa GA800s at the remote...
355
Looking for help programming LS electric XGB plc to communicate with a TECO A510 vfd using modbus 485.
672
Hello: I am confused about the A510 modbus addressing scheme. According to Teco's communication addendum the modbuss register addresses start at...
1,695
Hi guys, I've never used a Teco PLR like this and I'm hoping someone might know what I'm up against here. I need to connect a chain of wall...
1,206
Hello all, I am completely new to PLC programming and automation in general. I am working for a company that wants to use a TECO SG2 PLC to...
1,522
