Telemecanique Profibus-DP Module Questions
jstolaruk
Dec 2004
Detroit, SE Michigan
3,912
I'm not extremely familiar with the Telemecanique line of PLCs and prefer to get answers from these boards because of the level of expertise.
I'm integrating a new robot loaded CNC machine (OP53) between two other machines (OP50 & OP60) connected via a conveyor. I need to do some handshaking signals with OP50 & OP60 and because my cell controller can only talk Profibus with the CNC machine, I was hoping to extend the Profibus network to the exiting machines.
The cell controller will be a TSX Premium, probably a TSXP572623M processor and I'll have a TSXPBY100 module in the rack.
OP50 & OP60 each have a TSX P57 202M processor mounted in a TSX RKY 12EX rack with one available slot. I want to add the TSXPBY100 module to each to facilitate the handshaking.
So my questions are:
Will the existing cells using the current processors support the Profibus module? I assume so because I was able to add the module in the h/w configuration (PL7 Pro v4.5) but I hate to assume.
Can the TSXPBY100s work in a "slave" mode (verses scanner) or do I need a DP/DP coupler with each to connect to my cell_controller-to-robot network?
Thanks in advance.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
252
Hello! Sorry for the unusual question not quite on the topic of the forum. We have a computer museum. We got an old PLC programmer telemecanique...
1,631
Good Afternoon , I'm not too familiar with the Telemecanique Compact Smart Relay SR2B201BD . Is the software free , and would any of you...
1,574
hello I am facing a problem! we have a TSX17 old telemecanique PLC on a machine the machine was off for a several years so the PLC battery has...
3,449
Hello All I have a project for upgrade a Telemecanique XBTG6330 HMI I, can not Find the right software for it and programming cable any Idea...
1,046
