Telemecanique - TSX17 - Tasks
rlmts said:
Without the original supporting docs, is it possible to establish which PLC memory locations the XBT HMI writes to?
Hi Rich,
Yep...you should be able to look at the stored messages on the XBT and see which variables they're 'connected' to in the PLC
You need to get the XBT terminal out of RUNNING mode into CONFIGURATION mode then step through to the MESSAGES DISPLAY sub-function which will allow you to scroll through the messages.
Here's a couple of guide sheets:
Thanks Kevin, very helpful, will print and take with me when next time I visit site. Thanks again!
Also anyone....
"Also, the TSX 17 has it's 'Fast Inputs' 24 and 25 connected, I read that if one of these changes state, this also 'calls' the 'FAST' task. Is this correct? I am confused about the fact that the Fast Counter also 'calls' the same FAST task. There's not much code programmed in this FAST code (see previous post attachment)
There was also mention in one of the Telemec documents that the 'Fast Inputs' must be configured as such? Where can this be seen to establish if they are configured as 'Fast'?"
Any ideas?
Hi Rich,
I would say that the event triggered inputs I0,24 & I0,25 have NOT been configured to call the Fast Task in this case, as if they had, they would appear in the code in the Fast Task.
Kevin
Does anyone know if the PL7-2 Software still available from anywhere? I am working with a print, and really should get on-line with PLC to confirm how some TSX instructions operate (in particular, the FC)
Rich
Then there's the PC/PLC coms problem I guess? Interface cable info anyone?
hello I am facing a problem! we have a TSX17 old telemecanique PLC on a machine the machine was off for a several years so the PLC battery has...
3,444
Hi, I’ve been a long time reader, and now this is my first question... I have a Telemecanique TSX17 PLC which I need to upload the code from...
8,293
We are upgrading a Tememecanique TSX17 would anybody know a automation service near Kanasa City MO. that could possible get the program off the...
1,692
Hi, I have been asked to look at upgrading some kit from TSX17 to one of the Rockwell (AB) platforms. The existing installation is poorly...
7,426
I have a tsx 17 telemecanique and PL 7-1 program, and i need the ladder diagram.
2,587
