Telemechanique TSX 17 Programming
BrendanDixon
Oct 2012
Durban
19
Hi All,
We have a problem with a machine not working. Upon looking we found it has a Telemechanique TSX 17 PLC.
I was going to look at buying the software so we can see what is going on. But I see it is a dos based software and no longer sold. I am not familiar with this specific PLC.
I have the following lights on
Run: Green permanently on
Bat: Red Permanently on
I believe this tells me PLC is programmed and running and the battery is running low.
I looked for a battery but cannot find one. It seems at the top right of the PLC there is possibly a place for a battery but there is nothing connected.
I also found it has 2 plugin modules in the center of the PLC
Left Module: Log. PL7-2/TSX17-20+CPL TSX17-20/PL7-2+CPL Soft.
Right Module: Cart. EEPROM 8K Octets EEPROM Cartr. 8K Bytes
I am assuming this PLC is using an EEPROM memory so I do not have to worry about the battery. It this correct?
Then connecting to the PLC. can anyone tell me where I can get the PL7-2 Software and configuration for making for the programming cable. I understand it is RS485 so we can see what is going wrong with this machine.
This is not as much about file management, moreso utilising the application s/w to determine versions etc. I had a customer today mention that...
1,335
Hi, I have been given the task of extracting a program from a Telemechanique TSX 21 but have no manual or software. Any clues at all as to where...
4,498
Hi, I created a program and compiled it with no errors, changed the program hardware configuration to match the plc. If I try to connect I...
1,919
Been a while since I've posted but here goes: I'm using an old Modicon Telemechanique Premium PLC Model: TSX 572623 w/ Ethernet (now taken over...
1,768
Why are these things anywhere from $150 - 250? A unix bit by bit copy of the card doesn't work. Anyone smart enough to reverse engineer the...
3,177
