Temperature Data Acquisition
Preeya
Nov 2003
112
I have 20 J type thermocouples and I need to find a suitable data acquisition system for it. I want to get the values preferably on an excel spreadsheet.
Is it possible for me to find a solution for less than $2000 but at the same time a reliable one?
Preeya,
For the hardware: sure you can
If you are looking for a PC-based data acquisition system so i suggest this company: www.adlink.com
the have both PC-based DAS alternatives:
1- PCI-plug in daq cards.
2- RTUs.
I think that the seconed alternative is cheaper but it will be harder to communicate with.(serial communication - RS485 interface)
Note: they have an OPC server for these modules.
So if you like the idea, go for this module (Nudam 6013)
You are simply going to connect your thermocouples directly to these modules (no signal conditiner needed)
and each module has 8 channels, So you will need 3 modules.
The unit will cost you -if i still remember- about 150 dollars.
Now speaking about the software:
that is the expensive part.
and you didnot tell what you can do?
And I think that building a small software is the best choice for this mini project (using VB or LabVIEW or somthing similar).
The problem is how much is the programming language ?
LabVIEW is very expensive, VB is reasonable.
best regards.
Dear, My problem is how to read special variables (pressure, temperature, ...) from tcp raw data stream generated each 100 milliseconds and use...
2,505
Hi all, Do you know if exists such thing of a temperature controller with data logging capabilities? I need to open/close a valve according to a...
5,532
Hi all, I have a question for all you hardware gurus out there. I am looking for a neat solution that can accept 24 thermocouple inputs and...
3,263
Hi everyone, We've came across a project for trending and historical trending from 2 Yokogawa UT temperature controller. The Controllers have...
5,181
Hello Folks, I have two watlow controllers that have two J-type thermocouples connected to two heating block on a sealing equipment. The...
56
