temperature instead of a switch
sas11
Mar 2008
Virginia
36
Everyone on this site has been a big help. I believe i am on my way with my plc project. Despite the problems due to my lack of experience i am enjoying the learning curve. I have another question. I have my program very close to what i want using switches for temp, pressure, etc. However the more I learn the more questions arise. Is it possible to say, for example read my actual pressure as it goes up and down. Maybe a transducer? if possible I would have no idea how to include in my program but it would be nice to have this ability and view it live on the display.
Thanks Again.
I have not read your other thread(s), but you are correct - to read an analog value, you will need an analog transducer at some stage.
To read that in you will need an analog input in your PLC, and they come in several flavours. There are thermocouple inputs, RTD inputs, millivolt inputs, voltage and/or current inputs. Another way would be to use something similar to a digital thermometer with a serial or other type of digital communications out, and read the values it could send out.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
96
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
227
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
627
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
233
I have an old Chinese Temperature PID controller XMT 8038c2kp that am able to send and receive requests via Modbus poll test center in this format...
446
