Temperature sensing
MervinXF
Feb 2017
Kerala
Hey, I'm currently using an ABB AC 31 40 series PLC and i would like to measure a temperature between 45-50 degree celsius. Please do recommend a suitable sensor which can be connected to the digital input side of the PLC.
A temperature switch will tell whether you are above or below the setpoint, a switch is likely to be more expensive than getting an RTD input card and an RTD sensor, which will give you accurate analog measurment values.
Do you have a particular temp switch in mind? When the temperature reaches 45°C the PLC should read this input and then produce an output to start a heating coil.
See my edited post above.
A switch is not going to give you a temperature reading just a on/off at a given temperature set point.
That describes the functionality of a temperature switch, thermostat or a temperature controller.
Why use a PLC to do what a stand-alone temperature seitch will do? For that matter, a single loop temperature controller with an RTD input is probably less expensive than an RTD input card and it's got its own HMI built-in.
Hi all, Looking for a temperature sensing solution for determining ambient temperature in the frigid Canadian winters. Discrete outputs are fine...
1,509
Hi, thanks for the supports to my programming needs. i now have some questions 1. how we are configuring an analog input module (1769-IF8) to a...
3,472
Dear, i am looking for distributed temperature sensing device which use fiber optic cabling. and it is rack mounted. thanks for any help...
2,007
How do major PLC manufacturers (Allen Bradley, GE, Siemens, etc.) get the temperature sensing signal for a PT100 or PT1000 into a PLC? Is there...
6,167
Hi All Using Step 7, ladder logic. I need to program the following sequence: If temperature starts to fall, open internal fuel gate to feed...
2,589
