JNTurcotte
Hi All,
I made a post regarding my personal project.
I think it's started to make more sense in the direction I want to take.
But I would like to find a way to reduce the cost of the temperature sensor.
Since most PLC will only accept analog input, or will require expensive thermocouples input cards. Is there a way to lower my budget on this ?
Is there other solution than thermocouples + signal conditioner ?
My temperature requirement is
Functional range : 50-120F
Full range : 0 - 150F
tolerance : +- 1F (but could accept more if price does make a big difference)
Reading : Surrounding air/surface element (flexwatt heat tape)
Otherwise, do you have any suggestion for not soo expensive signal conditioner ? (0-5V ideally)
Thank You very much once again !
