I was starting to suspect a memory module here as well.
If you do have a mem module, to quickly check what Bernie has suggested...
Go to "Processor Status" - > "Mem Module" tab and see if the S:1/10, S:1/11 or S:1/12 bits are set 1. These are the three "Load Memory Module..." options. If any are set, then a mem module is installed and its program is being loaded each time you power cycle the processor.
Also check if the "Program Compare" bit S:2/9 is set 1.
This bit prevents changes being made to the program stored in the processors Non-Volatile RAM (NVRAM), so the program in the memory module and in the processor remain identical.
It disables online editing, program downloading and clearing of the memory.
I'm not sure from memory, but I thought the S:2/9 bit disables all online editing features, so if it is set, and your online, you should not be able to get as far as you have been with your edits? I may be incorrect.
G.
