The Rockwell Discontinuations Will Continue Until Supply Improves...
CLanford
May 2017
Charlotte, NC
74
So I just received more bad news from my Rockwell rep. Apparently they are discontinuing the following products:
Kinetix 3, 300, 350, 2000 and everything in the Ultra 3000 line :eek:
My rep put this in an e-mail, and he was hesitant to do the same about the Micro1400's a few weeks ago so it makes me think it's definitely happening.
I'm getting more info about what they're actually discontinuing (parts, support, etc) and I'll update this thread.
Has anyone else heard about this?
Found out about Kinetix 300s from our distributor a couple months ago, but not the others. Thanks!
I found out about the Kinetix discontinuations at an expo my distributer held a couple of weeks ago. It'll be all Kinetix 5000 going forward.
ML1400 has been moved to Active Mature, and I'm being told to not put it into new applications. I was being told that a couple of years ago, but now that Rockwell has changed the product status, it seems more real.
Also, be aware that the SLC I/O will all be discontinued at the end of this year. For some reason they did the I/O before the processors.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
172
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
129
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
