three phase inverter system
ols1570
May 2014
Tirana
Hello everyone
I ve bought three inverters dc to ac. The input is 24V dc and output 230V ac. Each of them 3kVA. I want to link them together to obtain three phase system 400V. Any idea if i can make that?
Thank you
If the output each inverter is single phase, I don't see how you could maintain the phase angle between them. If the output of the inverters is three phase, then you will need a transformer connected to the inverter output to step up from 230 volts to 400 volts.
it means you are running 450 amps in total on the 24 volt line, You will need lots of batteries to get this.
So a little knowledge would be fine, however, this is not a subject for a PLC.
have a look at arduino, or a specialised IC like Texas Instruments.
another one is using a UPS.
what is needing so much power and only 24 Volt is available.
if it is indeed batterie operated it is simpler to make the batteries in series same like a PVroof. when putting 10 batteries the voltage is 240 volt, putting them in Star gives nice 400 volt, the currents are a lot less, and no need for transformer
only a simple VFD is enough.
Just make sure you set the batteries on the ground in the form of a triangle with a 60o angle between them or you won't get the right phase relationship.
a normal VFD is in delta thus the DC voltage is 1.4 *800 is 1120 volt.
and wow i think the OP has not enough experience in it.
Hello, I have a application where I have a threepase transformer that gives 22V AC 50 Hz. I use A Three Phase Rectifier Bridge to make DC...
1,923
I'm not having luck finding a definitive answer to whether I should use Time Delay or Fast Blow fusing for 480V, three phase, 36kW heaters. I've...
2,654
Hey, this might be a simple question, but I don't think I ever ran into it before. We all know that on 3ph, any two leads can be swapped to...
26
6,933
Hi everyone, I am part of a senior design group that is building a dynonameter to test shocks. We are ordering parts tomorrow morning and so I...
17
10,106
Dear all, My machine will connect to three phases power 208V, but some of my electronics in the machine need single phase 110V . Where I can...
3,019
