Three powerflex drives failed upon powerup
ziyaddin2015
Nov 2019
USA
84
Hi all,
We had three drives fail upon power up. The two had F081 fault code. The maintenance personnel attempted to copy VFD parameters using a HIM with no luck so they decided to change them anyways but they could not get the motors to work because some parameters needed correction I downloaded RStudio locally so I can go online with the project and compare the parameters but that didn’t work as well. I can only see and edit parameters while offline not online even though it should a Ethernet connection but seem it’s missing something. The drives are on 22 e-comm. Can this be done using a messaging but that could be a tedious and long process. I am not exactly sure how that’s done either. Does anyone has any suggestions? Thanks, Ziya
My bad. Is there reason why I am unable to correlate settings while I am online with PLC when I click drive tab to pull up vfd settings? Thanks
Monday, we had a VFD that controls the spped of a conveyor belt fail on us. Took the replacement out of the box, installed it and bam, it failed...
37
16,858
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
206
Kindly, we connected electrical power, 3x380 vac, between a supply station and an electric cabinet, away 180 meters. The calculation software...
851
im new at Allen bradley rslogix programming; i have something to ask you guys , and i will be happy to get answers so thank you in advance. when...
591
Wondering if any of you old timers have seen a case where you can download to the processor no problem, but on power cycle: fault, and no program...
2,124
