Throttle Back Mode
PatW61
Nov 2015
Martinsburg
In my conveyor system I have what we call a throttle back mode on a conveyor what happens is you can hear and see the belt speed up and slow down. When it comes to the ladder logix in my AB 5000 where would I find this
Where you would find this is completely up to the original programmer.
I would look for a routine with the drive as a title or some routine in your program that handles the speed references for your conveyors. Obviously you have at least a couple different speed set points or some scaled value that is being moved to the drive reference based upon some condition.
It would also help to know if your drive is in the project tree as a drive (Ethernet IP ) or if you are sending the drive an analog signal. It could also be a pre determined set point in the drive based upon what inputs are active to the drive.
There are many ways this could have been set up and you original post does not give nearly enough information to give you an answer.
It may help to zip and post your program, perhaps somebody will look at it for you.
I'm starting to piece parts together to build a genset. I believe I will be able to buy an Isuzu C223 engine that was originally in in a truck...
1,834
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
166
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
105
Hello everyone, I need your help to guide me how to make this screen appear when the alarm is present, I have already configured its size and the...
159
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
185
