TI 505 remote IO and S7300 CPU - Analog values
avasiena
Jun 2008
A
I am trying to scale analog values in a system with a S7-300 PLC and TI 505 remote IO. The remote IO uses a CTI Remote Base Controller connected via profibus.
The TI 505-7016 analog input card uses WX values from 0 to 32000. Step 7 has an analog range from 0 to 27648. Do I have to rescale 32000 = 27648?
0-32000 is the range for 0-20mA. You should be able to use simple math to covert the raw counts to an engineering unit. If the device is 4-20mA then the counts will be 6400-32000.
I will assume it's 4-20, and the scaled value is 0-100%, here's an example for scaling:
EU= (WY-6400) / 25600) * 100
hi, is there anyone that already know how to using remoteio. i find a point io 1734 POINT I/O but that is for the controllogix. i looking for...
1,358
Hey all, I am considering using Ethernet style valve packs for a new machine were building. They are priced reasonably, and would certainly save...
8,702
Have 1746-NT4 Thermocouple card installed on remote I/O rack working thru channel 0. I need to program another channel and need help. This is the...
6,272
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,267
