Ti 530c
Fredy,
Do you mean the range of values inside the CPU?
In this family of PLCs, all the analogues were ranged between 0 and 32000. If you had a signal which had no offset at the bottom end like a 0-10V then 0V=0 and 10V=32000. If you had a signal like yours with a 20% offset at the bottom end, then 0mA=0, 4mA=6400 and 20mA=32000. This also gives you the advantage of doing checks for a faulty transmitter or wire-break. Anything less than 6400 (or say, 4800-5400 if you want to check as far down as 3mA-3.5mA) can be assumed to be faulty. It doesn't matter what resolution of card you're using. All the data was left-shifted in the word, so it was always the Least Significant Bits which were affected, hence the constant range. It made transport of code really easy in this family.
Good luck
Ken
Nope.
Sorry, the 530C was limited to integer arithmetic only. You're thinking of the big brother, the 565 with all the bells and whistles.
Regards
Ken (the other Ken)
I need to try to get an upload from a Maple HMI 530C-004. Is anyone able to tell me what software I need and where I might be able to find it...
1,571
Good Day: I have a used piece of equipment that has a TI530C processor in it. I need to access the PLC to get the ladder logic as we are going...
4,936
I believe I need help with the proper cable connections to allow a 9-pin serial port on a laptoop to talk to a TI 530C Processor. I am trying...
8,839
Here at the plant we have an old TI 530c processor. It has all 120v descrete i/0 cards.The problem is I am attempting to utilize one of the unused...
2,784
I have a customer still using one of these, and it recently quit on him. Does anyone know if there is there a battery in these processors? If...
2,573
