RoTaTech
OK, I'm getting kind of fed up with TI; 565 anyway.
One card (so far) since we fixed the comms problem, has an output problem.
When the PLC - ladder or forcing turns on an output (Y1059, 120VAC solenoid) on this card, the indicator lamp goes out, and the output does not come on. Other outputs and lamps stay lit. Force on Y1060, connect output to it, same issue. Remove wire from output terminal, lamp comes back on.
Check all fuses - good. Check AC inputs and commons on card - good. AC is solid 120, neutral is present.
Exchange card with a good one, same issue.
Hook solenoid up to another card on a different rack - works fine.
For some odd reason, too, the lamps seems to stay lit even when the PLC is in program. It's as though there is some strange leakage to common inside the card, but they are not that dirty.
Ideas are welcome ...
