TI to S7 Comunications
Hilgard
Jan 2008
Rustenburg
Hi All
I have a lot of TI and S7 PLC as well as AB. I have a SMS Module from AB from which I am sending SMS notifications out. I want to do the same for the TI and S7 PLC's. Can I send a message block from TI to S7 PLC over ethernet? Do you get a SMS module for S7 or TI?
Hilgard said:
All the PLC's are remotly situated and I have only Ethernet access.
Hello Hilgard;
In this FAQ from Siemens, you will find 3 options for Ethernet connections between a TI505 and a S7-300/300 PLC; the choice will mostly depend on the hardware available on the TI PLC (note that the FAQ dates from 2004; newer CPx43-1 support both TCP and ISO-over-TCP connections).
http://support.automation.siemens.com/WW/view/en/5854042
You will also have access to specific FAQs for the connection type you select.
Hope this helps,
Daniel Chartier
Edit: In case you need to study the TCP/IP connection (with CP2572) in more detail, here is a link to the Control technology applications page; they developped the TI modules for Siemens while the product was sold as Simatic 505; they now propose a new line of CPUs that enhances the old TI505-1106 potential, along with new communication processors:
http://www.controltechnology.com/support/application_notes/
Regards, DC
Hi guys, I need know if someone achievement communicate a Micrologix 1400 with a Movidrive-B. If so as it has done and what protocol to use and...
4,411
🔨 Saturday morning early we had our control net communications go down on our flex logix racks. We have 3 pc’s & 6 Racks & 1 powrflex 70 on...
3,277
Hi All, We have a Bosch PLC/CNC system running a lathe. I have a problem that while the machine is standing still I keep getting a measuring...
1,775
