ti405 question
goxx
Jan 2005
84
i am using V1400 thru V1426, they all get a value during a fault, do some adding and give me a number. isn't there a way i can reset them all to zero using one box?
thanks, and happy st. paddy day!
If your CPU supports it you could use the FILL instruction. It takes a couple of loads to get all the information in that you need but it should work, assuming your CPU supports it.
Keith
yea, i can make that work, that's exactly what i was looking for. overlooked it in the manual, knew there had to be a way, tho. thanks a bunch, keith!
We have a TI405 where the battery light is flashing. I can't find any literature online about changing the PLC's battery. Has anyone doen a...
2,372
hi friends,we are asked to replace an existing ti405 series plc with any siemens brand without changing sequence of operation and...
6,998
Mike6158
M
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
74
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
170
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
90
