TI555 texas instruments PLC ASCII string help
Mike Lewallen
Jun 2009
Ohio
I need help writing code that sends one real # out of a serial port (RS232)in form of an ASCII string.
The processor is a Siemens (Texas Instruments) 555-1105
The serial port module in the rack is a 505-2571
The software is either TISOFT or Workshop.
So, short answer, you need to set the module dip switch for the port on the card you are using to PLC select.
Then, create both a "create connection command" block and a "Write command" block. I often set most of these using a special function set to cyclical w/ a 5min timer.
ftp://ftp.controltechnology.com/public/Pubs/PRODUCTS/257X/06200182.pdf pages 18-20 for the format of those blocks.
But read the whole manual and note that you'll be using the GAS protocol manager.
I have inherited a stinker of a job sadly. Customer has a Siemens TI-555 CPU on a Uniloy Blow Molder. I need to get online and interrogate some...
2,228
Hello: We have a number of Ti555's around the patch. Most are hooked up to our process network and I would like to remotly check the status of...
2,974
How can you communicate data between the S7-200 and the Ti555 via PROFIBUS DP
2,565
I'm wondering if any of you know of or have some suggestions on HMI's to interface on a TI555 system? I've got this one system with 16 RBDs...
3,164
Anyone know of a good place to take PLC classes or anyone looking to tutor a PLC novice in the Dallas, Tx area?
2,658
