Tia Portal 17 Split instruction
steu
Aug 2006
Milan
17
Good morning
I have a 1500 CPU with a RS232 card.
I receive fom serial card a string like:
123.45 1457.23 456.34 892.34
I need to split the string in array of string with a value for each string of the array.
To do this I thought to use a split instruction using a space like separator, I'm not able to use this instruction the Help on line is not well explained.
Can someone write down an example with the parameter of FC?
thank you in advance
... To do this I thought to use a split instruction using a space like separator, I'm not able to use this instruction the Help on line is not well explained.
Yes; see below.
OP will need to adapt this example, i.e. use the delimiting (SPLIT.RecSeparator) and terminating (SPLIT.EndSeparator) character suited for their own process.
An alternative to the Equals comparison instruction (-]==[-) would be to always write a 0 into the [SPLIT.Position] parameter (misc.start_pos in the example) just before the SPLIT instruction on each scan, so the SPLIT instruction will perform the splitting on every scan.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
35
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
20
342
273
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
214
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
188
