TIA portal - add PC or unknown
rQx
Oct 2010
Trelleborg
1,051
Hi!
I use TIA portal and have two CPU.
I have two WinCC Flexible Runtime.
Just to have control over my project I want to insert some "dummy" box in the network view to represent the two runtimes and computer.
Is there a way? I can't insert RT and PC in TIA portal since I only got basic license in TIA.
Any suggestions?
/Tim
Where do I find this?
You don't meen s7-1200 unspecific? Cause that I have already tried, and can't connect or assign IP number to it.
I forgot to say that, I wan't it so that I can have control over the IP adresses when the project grows larger.
If all you want to do is reserve the IP address that should be easy enough. You can't assign an IP address to an "Unspecified 1200", but if you just create one (any 1200 model, it doesn't matter), you can place it on the network and assign the IP address to it. Name it something like "Placeholder PLC" or "IP Placeholder", and then just don't program anything in it, or try to connect to it.
That way nothing else will use the address later on in Portal, as long as everything is assigned to the same network.
no, no, unspecified is for unknown PLC upload. i don't know out of my head at the moment and i left my laptop at work, but there should be something where you can insert as a station (not RT) and add IE general module that have its IP, even with basic as i recollect.
A good suggestion, but then I will have many CPUs in my project tree, maybe not a big problem but in the future when I maybe have 10 it will take up some space. But if there's nothing else I'll take it.
Ah, I will look harder in the hardware catalog again
If you only have Step 7 Basic, I don't think it will let you do a PC station at all, to add the IE general like balash suggests.
However, something else you might be able to do is insert a profinet IO device, put it on the network, give it an IP address, and then just not assign it to a PN controller. The ET200eco PN is a simple block IO device that would be easy to add and not require any config besides the network. You could use any DI/DO/whatever module. It shouldn't matter, you won't actually be using it in your project.
That's a good idea, why dind't I think of that in the first place? To busy looking for something more "dummy" like I guess. That will work fine if I can't find balash IE general.
Thanks!
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,099
I'm getting stuck again. Operator enters date when calibration was performed. I want to ADD 6 months onto that date - this will be the due date...
1,147
I have a small system controlled by a Siemens S7-1200 PLC. I created a totalizer function block (TIA v17), where I'm counting total revolutions...
3,160
Hi all, I am having trouble with some programming. I have a system that needs to calculate a date e.g. 60 days from start date but i am having...
2,357
Hi,I want to add a CPU that is not present in the library of TIA portal . Does someone can helpme ? i am using tia v14.
2,520
