TIA Portal, bit to word... ?
userxyz
May 2002
any
2,768
Hello,
I need to trigger bits in a Word.
This for a 315 CPU in TIA Portal, placing .b0 behind it will not work :)
Thanks in advance,
Kind regards,
C
Hmmm
This is how I made it:
Code:
      L     #TempWord
      LAR1
      A     "STD VENTIEL VISU".EVP001."ALARM n"
      = [ AR1 , P#0.0 ]
      A     "STD VENTIEL VISU".EVP001."ALARM p"
      = [ AR1 , P#0.1 ]
      A     "STD VENTIEL VISU".EVP001."ALARM p n"
      = [ AR1 , P#0.2 ]
      A     "STD MOTOR VISU".M001."DRIVE ALARM"
      = [ AR1 , P#0.3 ]
      A     "STD MOTOR VISU".M002."DRIVE ALARM"
      = [ AR1 , P#0.4 ]
      L     #TempWord
      T     "ALARM INTERFACE"."Alarmwoord Unit 1"
This for making Alarm in a Comfort Panel... Integrated ??
TIA portal references use the following layout:
Word
.W0
Byte
.B0
Bit
.X0
As far as I know, the slice style addressing only works on the newer PLC's. If he is using a 300, he needs to do it the old fashioned way.
Combo,
There are two main ways I see.
  1. Create a Struct with all 16 alarm bits (or an array) to access the individual bits. BlkMove the Struct into the Alarm word you want the HMI to look at.
  2. Use Absolute addressing, which is messy
Thanks guys.
Combo,
I have a IPC427E, TIA Portal V15.1 SP1, WinCC RT Professional. This is a touch screen application, and I want set a bit on Click, and reset on...
3,162
93
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
194
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
119
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
48
