TIA PORTAL can't be linked to S7-314C- 2DP, via MPI
mourad69
Nov 2010
casablanca
Hi everyone,
We have a portal TIA V13, the USB cable adapter 6ES7 972-0CB20-0XA0, but after plagin the usb cable, there is only the PPI protocol through Com4 in On-Line access, so the MPI protocol doesn't appear, the first problem is that the driver is only supported by windows XP, i know that the portal TIA has it's driver integrated, I have already activated the port MPI in the configuration device level.
Many thanks for any answer!
Hi everyone, We have a portal TIA V13, the USB cable adapter 6ES7 972-0CB20-0XA0, but after plagin the usb cable, there is only the PPI protocol...
2,110
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
40
266
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
210
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
178
