mulderm
Hello,
In Tia Portal I put a motion block called MC-MoveRelative from the Technology instruction.
I choose an instance datablock and I want to move the variable to the block.
It will be red and after compiling I get an Error: the tag is read only
Using the help-function but will not help.
See also attached files.
Somebody knows the problem and a solution?
Thanks if you want to help me.
Greetings,
mulderm
Greetings,
mulderm
