Tia Portal Discrete Alarms - switching off falling edge ?
mihal__
Sep 2012
Warsaw
Is there any possibility to switch off alarm trigger mode "falling edge" in discrete alarms configured in Tia Portal ?
I have an alarm configured as discrete and I want to print a message on the screen when my bit changes from zero to one - and it works fine. But, when this bit changes back from one to zero, a message is printed again - is there any way to switch off this falling edge detection? I have nowhere found trigger mode for discrete alarms. I suppose that there has to be somewhere sth like this...
I really don't like this Tia Portal style alarm configuration :/
(edited)
You are probably simply displaying alarm conditions without having a memory of if the alarm is acknowledged or not.
You have to add the functionality that keeps a memory of the alarm until it is acknowledged.
You then set the alarm view to display unacknowledged alarms rather than all alarm events.
Aside from that, I do not recommend to have a window that pops up over the regular screen. It will be very annoying if there are frequent alarms.
Instead create a smaller alarm banner that displays just the most recent alarm.
And create a separate screen to display a list of all current unacknowledged alarms, and yet another screen that displays a historic list of alarm events.
106
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
125
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
51
22
489
