TIA Portal problems adding my CPU
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I am trying to create a project to download to my CPU312 (312-1AE13-0AB0) and I can't get it to add this device. The device and article number show up however, I select it and it does nothing more with it. I am not TIA Portal savvy at all so I am hoping it's just something I am neglecting to do however, going to Youtube University and watching videos mine isn't doing what others are showing although, there are no videos that show using TIA Portal v.18 for my exact CPU. I can only assume that, since the CPU is listed precisely, I SHOULD be able to use this software? This is what I am selecting, that is doing (apparently) nothing:
I should also add; it is installed on a VM that also has Rockwell Software on it. I am not sure if they play nice together or not?
So you get the spinning circle ? and then what happens?
and another thing to try is to drag it over from the hardware catalog to the network view...
let us know
let us know
The spinning circle goes away and I am left with the display of the 6 gears. Thinking I will check and see if it added it I then select add new device again, use the same name (thinking if it did indeed create it it won't be happy about the duplicate name), it does the same thing.
Hi, I have TIA portal V16 and I am trying to run a simulation but when I do this I receive and error stating "Failed to start runtime...
6,608
Hello all, Trying to simulate with TIA V15 because the hardware won't be ready for a few weeks. I have the PLC simulated and running. Can go...
12,529
Hi I'm wondering if anyone can shed light on how the below function works because I'm trying to remove it so I can optimize the DB linked to the...
2,875
Hello all, I am hoping someone can help me with an issue I am having with a HMI. I am trying to update a HMI using TIA prtal versions 13 and 14...
5,622
One of my engineers was on site doing a commissioning of a sister company's equipment. The PLC is one of the newer S7-1500 types. The original...
12,216
