toddp65
Hi All
While uploading a source code(program) from a machine (I have a copy, many copies) the uploaded version differed from the version I know is in the controller (1212 controller). I had been online with in the day before; when I brought PC to shop I didn't realize the charge cable wasn't plugged into strip...no charge, laptop died and I know I saved the project but can't find the exact copy. Anyhow, I simply did an upload into an older program.
However--it didn't pull up the PID Compact routine. I know they still exist but I can't view them anymore. They used to be in a subfolder called cyclic PID and now that's empty.
I did a second upload with a version of the program that still had them and made sure they uploaded--they did but now there on the tree but not in the section deemed cyclic PIDs with it's OB named Cyclic Interrupts. All of the OB and FCs are all stacked in the same section now instead of organized. But they all point to their respective OB but not separated anymore. Is this an issue? I'm assuming the controller knows where everything is but this is just the way I see them but everything is performing correctly.
Still going thru the ins and out of TIA portal as I'm more of an AB guy.
(Don't get me started as to why the HMI won't upload, only the controller)
Thoughts?
Thoughts?
