schui Member S Join Date Sep 2011 Location Toronto Posts 51 Mar 19, 2016 #1 Hi All, I have the following issue reading the status of an output (S7 1500 Fail Safe) The "TAG" parameter is not permitted. No read access is allowed to the process image of the outputs. Can someone advise on the solution Thank you
DeKemp Member D Join Date May 2013 Location Netherlands Posts 126 Mar 19, 2016 #2 Are you reading the output in a F block?
schui Member OP S Join Date Sep 2011 Location Toronto Posts 51 Mar 19, 2016 #3 DeKemp said: Are you reading the output in a F block? Click to expand... Yes
DeKemp Member D Join Date May 2013 Location Netherlands Posts 126 Mar 19, 2016 #4 Dont know if you are allowed to read a safety output, but why would you?
schui Member OP S Join Date Sep 2011 Location Toronto Posts 51 Mar 19, 2016 #5 DeKemp said: Dont know if you are allowed to read a safety output, but why would you? Click to expand... Ok so I must be missing something here how else can I know that it's on or off
DeKemp Member D Join Date May 2013 Location Netherlands Posts 126 Mar 19, 2016 #6 Where you set the output you could also set a merker and read the merker. Their are certain things you cannot do with F, dont know if reading an output is on of them as i never had a need to do this.
schui Member OP S Join Date Sep 2011 Location Toronto Posts 51 Mar 19, 2016 #7 Thanks very much for your reply
