TIA portal SCL monitor
moelsayed
Jan 2016
mi
41
Hello,
In step7 I would be able to access FB has been created by SCL and after assigning an associated instance DB i can monitor to debug the code.
But in TIA portal i found i have to search for FB in the code then find who is calling thus FB after that call and monitor I understand the TIA will will know which DB should be called and he will do that automatically.
But i am looking for the way like what I used to use in STEP7 which assign instant DB manually then start monitoring SCL.
How can i do that in TIA portal v15.1
Thanks,
Moelsayed
Enter the block through the project tree and turn on monitoring. At the top right of the working area is a button with a red ball. Click on this button.
You will be able to select either the instance DB or the call path to monitor. Select, then click "Transfer to manually..." (I don't remember the wording), then click OK
Please can you take screen shot for me I couldn't be able to find this button.
Alternate instructions:
Open the block and monitor. Open the Testing task card. Expand the Call environment section. Click "Change ..."
I have a ramp function which is using Time data type for calculation , I have converted the time to DINT and divided these values and saved in a...
5,351
I just found a piece of code using an operator "+=" IF tag1 AND tag2 THEN tag3 += tag4; tag5 := tag5 + tag6; END_IF; I don't...
4,832
Hi All, Just a quick question to see if anybody has found a work around for the symbolic / numbering of datablocks in SCL in TIA Portal V12 ...
5,703
Hey everybody, I've recently started messing around with TIA portal V11. Reviewing my company's software. A lot of it was written in poorly...
7,353
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
