Time Synching Panel View plus 1000
dhanad
May 2009
Can any body tel me whether the Panel View gets time from PLC or use its Real time clock, if its use its own can we change this time for Time synching purpose?
We are not communicating to PLC but to Panel view only, thru modbus, can we write time and date values using Modbus registers?
If you can create tags for (any or all of) Month, Day, Year, Hour, Minute, Second, then yes, you can have the PanelView+ sync to those tags (again, under Project, Global Settings).
In other words, if you can display external time/date information on a screen, you can have the PV+ Sync to them.
I have a production line that contains 3 separate pieces of equipment, let’s call them A, B, and C. Parts are transferred from A to B and then...
18
4,261
This should be a good one. Within my plc (unitronics V280), I am collecting data, and every 60 seconds, I cache this data to a buffer (11...
2,634
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
80
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
206
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
396
