Time_delay_interrupt
adam_lhadi
Feb 2022
algeria
59
HI everyone as a beginner i have been working with the time delay interrupt to understand how it works
the SRT_DINT instruction starts the counting with a negative edge in EN input
when disactivating the interrupt with CAN_DINT instruction the the counting stops but it give an error code 16#80A0 (Time-delay interrupt has not started.) rather than 16#0000 why is that
i didn't totally understand the use of the DIS_AIRT and EN_AIRT instruction and what's the difference between DIS_AIRT and CAN_DINT
when creating a time delay interrupt OB what's his cycle time (how long he last) what the limitations when putting a code inside of it like putting a timer
thanks for all please correct me if am wrong
kind regards
DIS_AIRT and EN_AIRT are for handling when multiple interrupts may interfere with each other.
They are not directly related to SRT_DINT, CAN_DINT, QRY_DINT.
The called OB only runs once. You generally dont program timers in interrupt OBs.
In TIA help the use of SRT_DINT, CAN_DINT, QRY_DINT is described with a link to a program example as well as a link to a general sample library.
What are you trying to achieve ?
I think that SRT_DINT, CAN_DINT, QRY_DINT are used when you want a hardware interrupt, but dont want it to be too sensitive, i.e. triggering many events on a signal that bounces.
i think the SRT_DINT, CAN_DINT, are used for time delay interrupt i didn't know that they can be used for hardware interrupt, because usually i use attach and detach for HW
about the interference of time delay interrupt we can use the offset that's what makes me wondering about the difference between the offset and AIRT and EN_AIRT instructions
Timed interrupts are exactly that, for example a 100ms interrupt wil trigger every 100ms & run the code in the interrupt OB. this interrupts the normal scan of the main program, there are limitations for example too many calls to interrupts could alter the normal program scan time, also if the code in the interrupt OB took longer than the 100ms to scan not all the code would complete or the interrupt would be triggered again before all code is processed, this would probably generate an error.
Build error occurs with TON ladder logic command. Time Input expected on block. Using Integer Tag under Control Local, and then hard number 19...
765
I have an SLC 503 running a machine with a scanner and 1794 RIO. One of the functions is a register motor on a printing cylinder. The manual 3...
1,280
Hello all, I am using a temposonic R series linear transducer for positioning of a lower ram on a hydraulic powdered metal press. The transducer...
1,944
My first post so I am going to try my best.:D I am totally new to RSlogix 5000, all my previous work was on 500. I am working with a...
5,590
In the code below I have what should be, in its current condition, a simple cycling up counter with a delay before recycling. But as it is shown...
36
8,196
