hoguegregplc Member H Join Date Aug 2023 Location McKinney, Texas Posts 10 Sep 5, 2023 #1 Build error occurs with TON ladder logic command. Time Input expected on block. Using Integer Tag under Control Local, and then hard number 19. Still can't build. I can't find any thing else to try.
hoguegregplc Member OP H Join Date Aug 2023 Location McKinney, Texas Posts 10 Sep 5, 2023 #2 TIME data type The PT parameter of the TON must be a TIME data type in order to build. Use the AnytoTime command to convert from the HMI INT over Modbus TCP/IP.
drbitboy Lifetime Supporting Member Join Date Dec 2019 Location Rochester, NY Posts 8,088 Sep 5, 2023 #3 Nice, thanks for the feedback, Greg.
