Hello Everybody!
I would have a question regarding restart timer topics.
I use codesys 2.3 with Wago 750-880 PLC.
Based on the attachment program part I would have if the timer(oTon), which is triggered by proba1 variable, restart from 0 when change a statement in the Else-If instruction. Now in case for example change one True ElsIf statement to an other True ElsIf statement, the timer resumes the run without restart.
It is only work in case after the Else branch.
Have you got idea to solve this issue?
Thanks in advance!
Thanks in advance!
