timer set up
john123
Sep 2010
london
18
:unsure:Hi, need your help please
afted high limit signal/ it starts the 20min time laps, the output turns off and stays off
I would like to change this to
during the time laps if the high limit signal is senced
the output is kept on for a additional 20 min ect
thankyou
regards
john
which plc u're using?
if it's s7-300 or 400
If you need extra 20 minutes you must put "off delay timer" before your output.
S_OFFDT TV= S5T#20M
Hi
the plc is a mitsubishi al20mrd
micro plc
would like to have a contionous 20min extension if high limit is senced at each time count down
hope this makes sence
regards
john
Hi pokajy
Thankyou for advise
yes turned off delay timer ,and added a second timer block
thankyou for your help works now
regards
john
Post the project zipped and someone will help
Have you got gx developer and the required cable?
My answer would personally be chuck it out and buy a proper plc (y)
most used plc
Hi
can i ask for some advise
what is the most used plc used
i will be getting a new one soon
mitsubishi fx3 ok?
regards
john
help with relay outbut change over
:confused:Hi all
can anyone help
plc output / i need to do a change over the polarity forword/reverce for motor
how is it done
regards
john
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
100
Hi there I'm guessing this is a straightforward one but after much experimenting I've been unable to find an answer. The software is TIA V16...
2,381
Processor: 1769-L30ER; Logix 5000: v32.02 I have an AOI that's been used in previous applications without issue, and have added a TON...
2,804
Hello Folks, I am new to Direct Soft, but a customer has a program that need me to edit. It is a DL06. We have a TMR function (T4) that we want...
24
5,739
I would like to use a numeric entry from a C-more HMI to change the preset in a timer in Do-More. How might I go about that? Thanks
1,303
