Eric Nelson
I'm a bit late to this thread, but here's a few observations on the latest version...
The 'Hoist Position' counter can easily get out of synch by repeated pressing of the fwd or rev buttons while at the 'on station ls'. Might want to make the 'on station ls' a one-shot (and debounce that input if needed)
The 'hoist lifting' and 'hoist dropping' bits can BOTH be on at the same time if the operator reverses direction before reaching an end sensor. Adding an XIO 'down pb' before the OTE on rung 3, and an XIO 'up pb' before the OTE on rung 5 is one solution.
Since the up timer's .TT bit 'seals in' the timing rung, it will continue until the up timer expires (32767 seconds later). You will need a way to reset the up timer when the operator removes the basket.
Since I see no physical outputs being used, I'm guessing this is just monitoring the system?
-Eric
-Eric
