Tips aligning things in FactoryTalk Studio
I find the alignment tool good for many but not all instances similar to the challenge described. In those instances I have become a fan of using the property panel which is on the far right of the tool bar. There is a field showing Left and another for Top. I will simply enter value. It is not as fast as align but works well. I will also use to help with spacing as it also have fields for width and height. So when spacing an array of buttons or indicators you can with a bit of math get your spacing precise.
Maybe I'm picky, but I make everything snap to grid, so it is easy to just re-size and move components.
Just like Autocad - it drives me crazy when I find other's screens don't align to the grid.
Yes but this is only to move the object. I would like to be able to resize it.
+1 on the property panel. select all similar objects to be modified and change the desired property. To make a line longer you change the width. To make a line thicker you change the Line Width. If you have selected all lines then a single entry in the property panel will change all. Do not right click on the selection but use the View navigation tab or Ctrl + V to open the property panel.
As far as alignment I like to use Alt + keys to align objects or space them.
To layout a set of rows on a page I will draw my first line.
I just learned about the Ctrl key method reading this post.:site:
Then Copy Paste the total number of rows needed. Set the Top and Bottom Position. Then Select All, Alt + A,L (align left) then Alt + A,V. (space vertical)
Have to add this one:
When you click on an object or group of objects and use the Shift & (arrow key) to move them pixel-by-pixel, the default number of pixels it moves per key press is 1 pixel at a time.
You can change the increment of how much it moves on each Shift & (arrow key) press by holding Shift & (+) or Shift & (-). Doing this, you can move it 1, 2, 4, or more pixels for each key stroke.
Hope that helps!
I’m currently starting a brand new design with a compactLogix controller and a panel view 700. I’ve completed similar projects from start to...
1,244
As I'm getting up to speed on some of the latest versions of TIA Portal, I noticed there is lots of security features. I'm wondering if anyone...
1,078
and go! I'll start. Always comment the Boolean instruction for their TRUE state. For example. It is much easier to read a normally closed contact...
65
21,585
I have been programming plcs and hmi's since the 90's. I would like to think that I have mastered my field/trade, but I know that I have not even...
856
My work laptop recently failed and I'm about to setup my new one. It will have RSLogix 500, Studio 5000, programs for - automation direct...
4,506
