Tips for my own project
Mar 2018
Sweden
Hello every one
I graduated from an automation education last year. At monday I am starting a new job at an automation consultant firm. But I want to do automation at my spear time as well.
Do you have any tips for which brands of PLC, HMI, fieldbuses, sensors and output devices and so on that are appropriate for a spear time project?
The idea is to begin small, like with a PLC and HMI, and than build on that. That could for instance be done by connecting different PLCs and/or HMIs with a fieldbus. Perhaps it could also involve SQL data bases as well.
I think I will put a purchase ceiling at 10 000 SEK which is approximately $1 400 and £1 000.
It would help a lot if there are available tutorials and/or manuals for the devices I would be working with.
Automation Direct has some cheaper PLC's, If your in Europe I believe Rockwell may be cheaper than it is in the US, but the programming software is expensive..
I would just make sure the software is not subscription based before purchasing something.
Siemens has some inexpensive PLC's, Beckhoff PLC's are inexpensive.
I believe Wonderware you can get a small tag license for cheaper, however Advanced HMI I'm pretty sure is free. You could also use Microsoft Visual Basic to make an HMI.
I would go for Siemens... you can get a TIA Portal kit with the HMI at a good price, I think they come with 1214 CPU's and can be expanded
Edit they have two, the 1200 and 1500, not sure if the 1500 comes with the HMI
https://w3.siemens.com/mcms/program...roller/s7-1200/starterkits/pages/default.aspx
https://w3.siemens.com/mcms/program...roller/s7-1500/starter-kit/pages/default.aspx
They have made a bunch of videos on youtube and will get you going https://www.youtube.com/playlist?list=PLdTU9QpgG0a0sIcNxKGQF5mQVpFM_tfze
Rockwell is always expensive...
I would go with Siemens, their lowest range S7-1500's is not very expensive and the S7-1200 is actually quite powerful for price and size. Every now and then you can also find some parts on eBay for it too, which helps the budget.
Other than that, I believe you can run Codesys opr Twincat in a raspberry pi. Not sure you'd want to, but can be an interesting device for testing that particular platform.
It would be important to learn with some brand of PLC widely used in your country, it will be easier to find a job.
Siemens is clearly used throughout Europe and I think Mitsubishi is also very common in your country.
There is allot that can be done and tested without spending much money.
PLC Programming Software (Free)
- Do More Designer - Built in Simulator c/w Modbus TCP communications
https://www.automationdirect.com/do-more/brx/software/index
HMI Package Free
AdvancedHMI will run on visual studio
https://sourceforge.net/projects/advancedhmi/
Database SQL Express - Free
https://www.microsoft.com/en-ca/sql-server/sql-server-editions-express
Android HMI - Low Cost
http://suppanel.com/index.php/en/
Once information is in a database, I would then look to share the information through ASP (active server pages) using a web server.
Regards,
For a cheap way to go I use Horner plus open source software, but I'm on a masochist level of programming. I've previously played with QModBus and am currently working with phpmodbus and/or a port of libmodbus to PHP. Not sure if you'd have interest in PHP, it's somewhat rare in the SCADA world. C# or C++ are good languages to learn for PLC's if you're into programming, and if not I'd say AdvanceHMI. In any case computer networking and understanding Modbus is essential.
Welcome to the forum!
Another cheap alternative is to use a raspberry pi with the Codesys soft PLC. It is pretty powerful.
If you are willing to invest into the Siemens package, that would probably be the most likely brand you see in your end of the world.
I’m currently starting a brand new design with a compactLogix controller and a panel view 700. I’ve completed similar projects from start to...
1,239
As I'm getting up to speed on some of the latest versions of TIA Portal, I noticed there is lots of security features. I'm wondering if anyone...
1,072
and go! I'll start. Always comment the Boolean instruction for their TRUE state. For example. It is much easier to read a normally closed contact...
65
21,555
I have been programming plcs and hmi's since the 90's. I would like to think that I have mastered my field/trade, but I know that I have not even...
851
My work laptop recently failed and I'm about to setup my new one. It will have RSLogix 500, Studio 5000, programs for - automation direct...
4,467
