TLP LogixPro error
Unregistered
Guest
U
Runtime error '429': activeX component can't create object, anyone help?
Without any more specific information only the most general answer can be given. The error comes up bacause an expected .OCX file is 1) Not installed 2) Installed in the wrong place 3) Is not registered or simply 4) the computer wasn't reset after installing if requested. So try restarting your computer. If that doesn't work, uninstall then re-install LogixPro. If you still get it and this is all the info in the message then give the guys at LogixPro a call.
It doesn't seem like the program supports it, but I'd like to be able to comment out a rung to troubleshoot the rung above it. I normally use the...
4,445
i need to complete exercises #1 and #2 for the advanced batch mixing lab with a description shown here...
1,932
Hello everone I need to make 33m cable for the TLP motor. What choice should I make about this? We will make the cable ourselves. What kind of...
1,024
I have recently downloaded TLP LogixPro Simulator and I am needing help in setting up. I started by adding a few Rugs, and found that only the...
1,843
Hey all, looks like the forum got updated since I was last hanging around here (either that or it's just been a long time.) Anyway, a little...
4,539
Unregistered
U
