TMC470 Communication
monach
Jan 2017
Michigan
I am trying to connect Telesis TMC470 to CompactLogix via Ethernet IP. I have setup the IP in the TMC470 controller, but I am not able to connect. What else I need to do?
Telesis doesn't have a built in Ethernet-IP adapter, I believe they use a Anybus adapter serial adapter or some other proprietary widget.
Try this for the IP settings:
Data-SINT
Input Instance 101 size 118
Output Instance 111 size 110
Configuration Instance 128 size 0
There is a pdf manual named "Ethernet IP Manual 70687B" that should be available on the web.
If you're in SE MI call Phil Theaker at PTR Sales in Walled Lake, he can steer you to what you need.
It's kinda crazy, but I've been fighting this same exact problem today as well. What are the odd's? Trying to get a TMC470 to communicate with a ControlLogix...
Good morning. I have been working on integrating a Telesis TMC470 using their #77918 ethernet adapter. I can get a string to send, but it is not...
2,341
Any one have any experience getting a Micrologix 1400 to communicate with a Telesis TMC470 Printer? If so what communication protocol did you use...
20
5,807
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
39
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
32
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
39
