Totalizing Tank by Volume
iMalinko
Mar 2016
Massachusetts
Hello, all. I’ve worked with totalizers based on a flow meter. However, I am trying to use ladder logic on totalizing a tank based on volume. I have a tank is consistently filled, and we have a level transmitter that shows the level in %. Based on this percentage and the maximum volume of the tank, we estimate its volume. The trick is, the tank can be emptied in bulk at any given time in the process. I am trying to calculate and totalize the amount that enters in this tank every day regardless when it’s emptied. Would someone be able to help out?
Is there any overlap in the tank being emptied at the same time as being filled? If so, then it's not possible to do this without at least one flow meter, either inlet or outlet.
If only a fill or drain action can occur at any one time then it's possible to calculate a rate based on level reducing or increasing, over a sensible timeframe. Use the rate to totalize.
Hello everyone! I've got something I'm trying to figure out and I'm possibly overthinking it. I've got a 25,000 gallon bulk chemical tank with an...
2,179
Is this reasonable to do? I am using a SLC 5/05 so there's no totalizing instruction, I think I have to make my own. Anybody done this, any...
4,344
Hi, please i wish to do batch totalizing ( automatic flow control) i wish to use Endress+Hauser flow transmitter with Allen Bradley 1400 to do...
30
6,073
Hey GE guys, wondering if any of you had any experience with getting the TOTALIZER instruction working in Proficy Machine Edition. Seems...
3,771
We currently have 2 system measuring a liquid similar to water. Density is around 8.3lbs/gal. We take the flow in lbs/min and calculate lbs per...
4,015
