Touch Screens versus Laptop
Lionel
Jan 2003
Another Question
For cost and simplicity reasons.
Can I get some input on the differences between using Touch Screens
versus using a laptop with the Loookout program? I can get a fairly
good laptop for about $500.00 on ebay and the Loookout program for about $400.00.
It seems like an eight inch color touch screen is kind of expensive.
Please give me your thoughts.
Lionel
1. What would prevent the laptop growing legs then walking away?
2. An HMI and a Scada/ HMI package are designed and bought for different reasons, you buy what you need.
3. A computer/laptop isnt specifically designed for industrial environments for day to day operation. You can buy them ruggedized for this kind of application but again the price increases. Interfaces are designed to be used in even very harsh environments in some cases.
This is another "It depends" situation, not knowing the usage or environment its hard to say, except for the laptop part. Use a desktop/tower type computer if its to be attached to a machine full time, less likely and too bulky to grow legs then walk away.
If its not going to be attached to the machine full time then what do you need with the HMI software?
There are HMI or Operator Interfaces available thru ebay and other places that sell used components for comparable prices.
Let me explain a little more. This Plc will be used in a motorhome for monitoring and controlling. The laptop should be safe. The only problem I see with the laptop is space. The problem I see with the touch screen is cost.
Have you looked into items like the TRI LOGIC PLC
Its not that expensive, offers analog inputs and has a display built in.
Some low cost HMI:
http://www.hmidirect.com/index_products.htm
EZTouch_Panels/EZTouch_Units
EZ Text Units
Optimate Panels
There are more but this should give you things to look at.
The problem with the laptop is the no power thing, being a MH I think you need to use something that can run off 12 or 24vdc and be available at all times. That is your decision to make though.
Touchscreen
You might want to give a look at the Unitronics Vision 280 PLC with built-in touchscreen. They are manys to go, just find a solution that fits your needs.
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
147
How to do wondare intouch Screens import & Export,how to make windows viewer
973
When using the Multi-State Indicator object as a message center for like alarms, I have noticed that if I have more than one message showing up at...
2,185
I've recently been asked by a customer if I can incorporate sliders for controlling a pump's VFD. Instead of manually typing in a speed, he is...
2,070
I returned to a facility that I had installed 3 Red Lion G310 Series Touch Screens to install a Factory Talk View workstation. The G310s have...
7,280
