Touch Scrren Replacement
asterof
May 2007
Califonia
554
using a PanelView Plus 10 inch no keypad Ethernet comms
talking to a Micrologix 1100
mechanic threw a hammer through it
Need a low cost replacement
What are the choices.?
Remember that the Logic Module is separate from the Display Module for these terminals. If the hammer didn't damage the Logic Module, you can replace the Display Module only.
PanelView Plus Display Modules did undergo a change from a 5-wire to an 8-wire touchscreen interface several years ago, so you will have to check with your Rockwell Automation reps to be sure you get the correct Display Module.
If you're looking for a total replacement, my advice is to consider the cost of re-development as well as hardware. There are dozens of inexpensive HMI devices on the market, and the advice for which one to buy depends heavily on your need for local support, product features, and of course hammer-resistance.
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
195
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
143
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
148
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
134
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
330
