TP 270 Siemens Touch Panel Communication
sajjadgazali
Jun 2009
10th of ramadan
I have Siemens PG M2 and I try to connect TP 270 touch Panel using Win CC flexible Software by serial and by MPI cables but all attempt are failed. ( I set Transfer at touch Panel also). I need your help guys regarding this communication issue. Please advice me how to make communication between PG M2 and TP 270? If it requires special cable, please write me part number or if it is serial cable draw the pin connection so I can make myself.
Hello, A TP270 is giving us some problems when starting up. Namely, the touch function does not work for some time (like half an hour), but the...
3,327
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,749
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,837
Hi there, I have a TP270-10" Screen that I cannot download to from WinCC Flex 2008... When in transfer mode, the TP270 has "Loader B 6.0.2.23" and...
8,484
Hi all, I have an existing application using a Siemens MP270 that has failed.The MP270 is connected to an S7300 over profibus. I want to try and...
2,911
