Hello guys.
I am wondering if anyone can help I am trying to connect wirelessly via a TP link router to a large Allen Bradley network connected via EN2Ts. I can connected hardwired via Ethernet no problem once I change my ipv4 protocol. My set up is below.
Tp link - set up as an access point, static IP 192.18.1.100 subnet 255.255.0.0. DHCP enabled with start address as 192.18.1.150 end address as x.x.x.250
Gateway 192.18.1.0
Plc network - numberous processors from 192.18.1.1 through to 192.18.51.1 subnet as 255.255.0.0
Laptop - WiFi card left as dhcp to retrieve ip from router. Ipconfig shows I have the address 192.18.1.250 subnet 255.255.0.0
When in rs link using IP driver configured to the laptop WiFi card occasionally sees processors on the network for around 30 seconds then they go Red Cross.
I can’t ping any processors as I just get a reply from my laptop.
Is it possible that my range needs to include the ip addresses I am looking for as I assumed it was only from issuing IPs in that range.
Look forward to your responses
Thank you
Gateway 192.18.1.0
Thank you
