Traffic Control Using Sequencers
bkole11
Nov 2013
Chicago
I am trying to program the traffic control simulation on logixpro using sequencers.
I have done the previous simulations with the stop light but i am at a loss with this especially with sequencers. Im using the following ladder logic so far and the programming for the sequencers but what else??
  • sequencers intergertables.pdf
I have posted solutions before, but in general, to trigger your sequencer, use EQU (Equal) comparison instructions that compare values of your T4:0.ACC (accumulated running time). For example, the first EQU (you need about 6 in parallel branches for my version of the program) should be "T4:0.ACC = 1". If that is true, then trigger the first output on the SQO. Then wait until your next light switch point, and trigger SQO again with the second EQU, and so on.
TIP: For me, it is much easier to use the First-Scan bit S:1/15 to MOV all the bits into the B3 file at start-up of the program. That way, you don't have to worry about having the correct bits in place. For example, when S:1/15 is ON, I first RESet R6:0 and T4:0 to make sure I am starting from the 0 point, then I MOV "17" to B3:1 (which is the 2nd word of my SQO, first being B3:0 and always "0"). Next I MOV "20" to B3:2, and so on with all the bit patterms for 6 steps of my SQO. It appears that you only have 4 steps. Is that enough?
I'm looking for a simple, cost-effective way to control traffic lights from a central location. The lights are actually mounted on signs next to...
1,885
I have just completed the Traffic Light Control with a delayed green light. What I am asking here is if my rung comments are easy to follow for...
4,462
Hey there, I have been doing all these exercises until this one where you have to control the pedestrians aswell. So my question here is, how do...
3,471
hello, could someone help me with a PLC with LogixPro I need? is a traffic control (only one traffic light), I need the green light flashing 5...
3,201
Hello, I purchased Phil Melore's Lab Manual which has been a great learning experience. I am on the Traffic Light with Horizontal Turn exercise...
1,943
