transfer of AB software with factory talk
robw53
Nov 2009
south yorks
515
whats the best way to swap software from one pc to another, i have 5k and 500 using factory talk activation, is there a walk through how to perform this?
rob
Rob,
The first thing to do is to download the Factory Talk Activation Manager from the rockwell site.
You can then Re-Host which activations you want to move. This means that the activations which are 'locked' to a device are released so that you can 'lock' them to another different device or hard drive.
I haven't done it for a while but I'm sure you need the serial number and the product code when you want to re-register the activations to another device.
As I say you need to download the Factory Talk Activation Manager to rehost the activation and its pretty simple to do. You then just get the activation back as if it where a new one.
Hope this helps
Mark
what if both the pc which has the activations on and the one i want to rehost it to do not have web access but i have another pc that has web access can i still do it then? because i watched a video on the rockwell site and it seams that either the pc that the activations are coming from or pc its going to has to be on the net.
please share me idea how to transfer the program of a burn out Proface HMI touch screen gp 2301-SC41-24v to gp37w2-bg41-24v.
3,279
dear all, sir is there any remedy to transfer aoj2 to medoc? becoz when i used software medoc to transfer it goes to failed,,is...
1,863
Hi All, I am using S7-300 CPU-317-2DP with IM 153-2 for Software Redundancy. I am using Ethernet as Redundant Link. When the Master PLC is...
6,622
Hi folks, How difficult is it to transfer ownership of Allen-Bradley software license? We currently have several licenses for RSLogix5 & 500, and...
7,358
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
74
