Triac Output Card
plcengineer
Jan 2004
USA
176
Gents,
I have a 1771-OAD card and it is bleeding voltage causing my relays to come on when I didn't turn them on.. I installed a 250 ohm resistor and it seemed to work fine but it got very hot.. It was 2Watt but I think I may need 10 Watts or so.. Is there an RC package that I can buy from Rockwell to do what I need? Any help would be appreciated..
Thanks,
This is interesting. Is this hooked up to a normal relay or a solid state relay? A regular relay should work fine as a load for a triac. Also a 250 ohm resistor is more than enough load to "turn off" a triac.
Something else must be wrong here, could you post a schematic.
All triacs bleed a small amount of voltage when the load is totally disconnected. Your triac on that output is probably bad if it requires a 250 ohm resistor to turn it off. 250 ohms with 120v applied = about 60 watts load, 27000 ohms would = about .5 watts with 120 volts applied. If you have no other choice, use a 25watt lamp instead of a resistor.
Good Afternoon, I am having issues with a triac output card and a solid state relay. The output is showing 120vac without a load, and when...
1,340
I just had a weird one last night and was wondering if anyone else has ever seen this. A SLC5/05, 7 slot rack. One thermocouple input, One 18...
2,134
Just looking to learn something today.... My understanding is that an output shorting on a SLC Triac card is a pretty standard card failure, with...
2,377
Just wanted to know what are people's thought on a triac output versus relay output cards? I'm working with the Allen Bradley SLC line, 1747-OA16...
6,508
Hello, I have a plc program that is not turning on the output for a triac output card. The conditions for the output in the ladder program are...
3,305
