Troubleshooting a servo motor
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I hate to admit this... I'm at a loss for figuring out if a servo motor is bad. A regular motor can have a megger-test. What does a servo have?
I'm working on a automated saw that matches a line speed with an encoder, and uses a control logix PLC to control a servo drive and motor to move the tabletop at the same speed while the saw cross-cuts the material. The servo stopped working and I'm trying to figure out why. I'm watching the ladder logic and during the "homing" function, the "IP" lights but there's no movement from the servo. I'll be checking one more issue that might be keeping the servo output from being turned on, but if that doesn't bear fruit I'll be looking at the possibility that the servo is bad.
Any insight?
Problem was solved. It was another reminder not to get too focused on electrical. The problem was a broken belt. A chat with the operator... "I could move the table top manually" raised a red-flag that the issue was not with the motor. A flashlight ended up being the only troubleshooting tool needed.
Anyway if you have a servomotor with permanent magnets, you can disconnect the motor, then joint the three fases of the motor and try to turn motor with your hands. If motor is ok motor it should be difficult to rotate. This is one test I guess there mut be others.
CNC machine: Servo went out, and was replaced. Still having problems, encoder cable, and drive replaced. Motor runs and faults. Amps go from 8 to...
3,349
Our Allen Bradley Ultra Series 200 Digital Servo Drive has been faulting out without providing a fault signal. After about 15 minuets of...
2,092
Hi All, I have a customer with an old system which I think was bought by Bosch who was then bought by Rexroth and I'm not having much luck...
2,845
In my recent "whaddafuh" post, I got alot of good suggestions, and some criticism on shotgunning the repair. No arguement, I don't like...
4,147
Hello All! I'm working on a basic troubleshooting procedure for servo systems. Nothing brand-specific, and not strictly PLC, but related :)...
3,462
