Trying to Open a Step5 project with extension .S5D
sanger
Nov 2005
Toronto
172
I'm trying to open a Step 5 project with a name in the form ****ST.S5D. I using STEP5 / ST VERSION 6.6 but it only seems to be looking for *PL.INI files.
Am I missing some files for the project or was this project saved with a different software package.
Thanks.
Step 5 should open the file as .s5d is the default extension for the program file.
Try this...
Hit F4 from the main menu or select FILE > PROJECT > SET, a menu opens up. Select BLOCKS from the tabbed menu. YOu can select the program file the menu.
Got It!
My Step 5 software was different that the one you're using so that didn't work. I ended up greating a blank project with the same name then just dropping in the new .S5D file and it opened fine.
I started by Installing Windows NT in a virtual box. For some reason my memory saved that experience as wonderful. Why, I will never know. That...
3,636
Hello all, Sysadmin here in the process of deprecating an admin account and creating a new one. As part of that I was testing to make sure that I...
2,424
Having a tough time finding a way to open old DOS era drawing files that I believe to have been created with Freelance (.DRW extensions). Anyone...
2,494
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
70
