tunnel sensors
Charbel
Jan 2012
Beirut
307
dear,
i was wondering concerning tunnel sensors, my preference is for IP66 for tunnel sensors such as visibility, CO, NOx etc....
however, most of the sensors are IP65, you can find IP 66 sensors from some vensors such as SVS1 sentry (visibility sensor) from envirotech.
My preference is for IP 66 is that the tunnel might be cleaned and this might damage the sensor, do you think IP 65 can handle cleaning?
appreciate your advice
thanks!
charbel
go for Ex units explosion proof, it might be needed as some units should work even when there is a fire in the tunnel.
Ex property and fire resistance are not the same. Ex equipment are designed in that way if it malfunctions it won't cause spark or heat or in any other way CAUSE a fire or explosion so it's anti-explosive
Fire resistance means only that it is resistant to open flame in certain degree. (e.g some cables that are resistant up to 90 min.)
Fire resistant materials are used in enviroment when power is critical even in case of fire (e.g. springler systems, server cabinets, emergency power) while Ex unit are obligatory in explosive enviroments.
Now considering that, i'd think since there is no risk of explosion in tunnel there's no need for Ex equipment i.e. extra cost (plenty of paperwork specific maintenance, certificates, etc....)
As for IP protection 5 in 65 is pretty high protectionfrom all directions, unless someone decides to use really strong industrial mini-washes during cleaning.
dear iant,
i was wondering if strong jet of water would be used and to be on the safe side IP 66 would be used.
It would be better if you can avoid that
What about a Perspex cover in front of the sensor. I understand the sending distances.
http://www.lpc-uk.com/omron/ind.htm
these are IP67 and IP68
other manufacturers have this equipment.
but I still would not rely on them surviving a direct blast of water.
the plastic moulding usually breaks down and water gets in.
QUOTE "Doctor Who - Waters of Mars" water always wins
dear, I was wondering since tunnel might be subjected to fire, does the tunnel sensor have to be specified as fire rated sensors? thanks a...
1,251
Third puzzle in the tunnel theme: Two cats are travelling on a train, the train is running at constant speed. The cats are initially stationary...
2,232
Just wondering if anyone ever had this setup. I have 3 micrologix 1400 communicating via cradlepoint modems. They in turn each is hooked to a...
1,687
Our project requires a vpn tunnel communication, between a Scada system and some remote Plc's. So we are trying to understand the following...
2,945
Hello all-it's been awhile. We recently bought a used machine and have made some modifications. The original machine had a Wonderware computer...
1,398
